2000 Pontiac Sunfire waterpump removal
2000 PONTIAC SUNFIRE
CURLYDOG
Engine Cooling problem
2000 Pontiac Sunfire 4 cyl Front Wheel Drive Manual i73 km miles
I cant seem to remove the waterpump after i removed all the bolts, does not want to slide out of the part where the gear turn the pump.
Jan 21, 2009 at 12:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You have removed all three bolts on the pulley and all four bolts from pump? Should come out once pulley is removed and four bolts are removed from waterpump.
Jan 21, 2009 at 1:15 PM
