2000 Pontiac Sunfire Serpentine Belt Tensioner Question
2000 PONTIAC SUNFIRE
MIKOSH6
  • 12 POSTS
Engine Mechanical problem
2000 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
Can just the belt tensioner wheel on my 2000 Sunfire with 2.4L engine be replaced or does the whole tensioner assembly have to be replaced? I suspect the tensioner wheel bearing is running dry on lubricant.
Thanks,
Mike
Jun 15, 2010 at 11:09 PM
BMRFIXIT
  • 19,053 POSTS
Yes you can replace just the tensioner pulley its about $10 to $22 this is a picture of the two
https://images.2carpros.com/forum/automotive_pictures/99387_getimage_4.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_getimage1_1.jpg
Jun 15, 2010 at 11:54 PM
MIKOSH6
  • 12 POSTS
Thanks for the fast reply BMRFIXIT. My GM workshop manual only shows replacing the whole assembly. If I can ask one more question; do I just put on a socket and torque the pulley bolt counterclockwise or do I need to block the whole tensioner assembly to stop it rotating counterclockwise as well?
Thanks,
Mike
Jun 16, 2010 at 12:32 AM
BMRFIXIT
  • 19,053 POSTS
no need to block it if you do not have the means to do it
use a socket and it should loosen up
Jun 16, 2010 at 4:37 AM
MIKOSH6
  • 12 POSTS
I've purchased a new pulley; would you happen to know the correct torque value?
Thanks,
Mike
Jun 21, 2010 at 3:08 PM
BMRFIXIT
  • 19,053 POSTS
install new pulley and hand tighten
install belt and then check the torque it should be between 30 to 50 ft lb
Jun 21, 2010 at 11:07 PM
