Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Sunfire
Engine
Symptoms
Runs Rough
2000 Pontiac Sunfire runs rough
2000 PONTIAC SUNFIRE
98,000 MILES • 4 CYL • FWD • AUTOMATIC
ALLEYCAT
MEMBER
2000 Pontiac sunfire runs rough and the catalytic converter gets red any ideals what could cause this problem
Jul 17, 2010 at 10:41 AM
Experienced Mechanic
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 17, 2010 at 12:35 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
