2000 Pontiac Sunfire Replacing a Serpantine Belt
CONNIEHOVDA
Engine Mechanical problem
2000 Pontiac Sunfire 4 cyl Front Wheel Drive 79,000 miles
Need help replacing serpantine belt, unable to get the tensioner to release.
Feb 1, 2009 at 6:31 AM
  • 110,248 POSTS
Hi:
The tensionier is spring loaded. Will it not release tension or is it loose and won't provide tension? Regardless, either way, it sounds faulty and should be replaced.
Feb 20, 2009 at 12:01 PM
