while driving without any warning my car just died,acts like it wants to turn over but won't-not the battery connections-any suggestions?
Jun 30, 2009 at 3:27 AM
JDL
✓Experienced Mechanic
Hello, if your saying, the starter motor cranks the engine, but the engine won't start, have a helper crank it, while you check for spark at the plugs and fuel pressure.
Jun 30, 2009 at 3:35 AM
LURENE
MEMBER
thanks for the response back- and will for sure check that possibility,although the car started just fine and was running fine as well -then all of a sudden when going around a curve it just completely shut down?
