2000 Pontiac Sunfire Low RPM / misfiring
2000 PONTIAC SUNFIRE
CAT_M77
Transmission problem
2000 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
I have a 2000 pontiac sunfire 2.2L that has been sitting for about a month and a half.
When I went to start it a few weeks ago it was misfiring and I couldn't get the car to drive faster than 40km an hour. A friend of ours told us that the 1&4 coil was faulty so we changed it along with the spark plugs and wires (which I can guarantee you have been changed properly). The car is still acting the same. The problem is still coming from the same coil but the coil is new....is there another part connected to it that could be causing the problem?
Nov 11, 2009 at 6:28 AM
MATTF87
I'm having the same trouble, read my post and see if that isn't the exact issue. It's detailed so that may even help you hunt your problem down faster. And could hopefully be more lucky then I.
Dec 1, 2009 at 2:15 PM
