2000 Pontiac Sunfire headlight Lens
2000 PONTIAC SUNFIRE
CENTREVILLE
2000 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
What can I used to get overspray (paint) of the lens of my headlights?
Oct 21, 2008 at 11:17 AM
DLOBI
  • 125 POSTS
Rubbing compound and a lot of elbow grease. If it won't rub out you might have to sand it out. I have fixed foggy/dingy headlights by wet sanding them with finer and finer sandpaper until I can then use buffing compound to get them clear again. I mean start with like 600 grit and work your way up to 1000 then 1500 or even 2000 grit. I would try just the rubbing compound first however.
Oct 28, 2008 at 5:48 AM
