2000 Pontiac Sunfire exhaust in cooling system
2000 PONTIAC SUNFIRE
58,000 MILES • 4 CYL • 2WD • AUTOMATIC
ECHSBLAZER
would having exhaust in cooling system cause the tempeture to raise and then cause the radiatior fluid purge itself into the overflow resvoir, therefor causing the fluid to overflow onto the ground. which then would make the low fluid light come on.
Mar 28, 2008 at 5:51 AM
MERLIN2021
  • 17,250 POSTS
This is technically known as overheating, and can be caused by a number of things, like defective, thermostats, cooling fans, or relays, bad water pump, and yes even a bad head gasket....
Mar 28, 2008 at 5:53 AM
