2000 Pontiac Sunfire Excessive Oil Leak
JENLAFATA
  • 12 POSTS
2000 Pontiac Sunfire 4 cyl Automatic 135000 miles
My car started leaking oil massively about 2 wks ago. At first not so much, but now oil is basically draining alomost right out. I've noticed today that the wheel well on the front passenger side is caked in oil and oil residue. It is also smoking when driven, but I think that is just coming from the oil leaking. What could this be?
Thanks!
Apr 1, 2009 at 12:09 PM
JAMES W.
  • 2,394 POSTS
Make sure your oil filter is tight and by the filter is the "oil pressure sending" unit. Check if this unit is leaking also. Let us know.
Apr 1, 2009 at 12:25 PM
JENLAFATA
  • 12 POSTS
Thanks!! The filter had a crack in side! I couldn't see it until I turned the car on with the tire off.
Apr 2, 2009 at 6:40 AM
JAMES W.
  • 2,394 POSTS
Glad you found it. Filters are a "lot" cheaper than motors.
Apr 2, 2009 at 7:03 AM
