2000 Pontiac Sunfire Brake lights will not work
129,000 MILES • 4 CYL • FWD • AUTOMATIC
TIMWOODALL1
My brake lights will not work. I have changed the bulbs and that did not fix problem. The hazards work and the turn signal light all work ok. Also the center brake light works but not the 2 rear ones. Can you please help with this Issue.
Thanks Tim
Apr 13, 2008 at 7:32 PM
  • 31,937 POSTS
Hi there,
If the centre brake light is working then it will be a wiring issue, you will have to trace the loom back and start testing with a test light to find the problem, It may well be a faulty connection plug or a bad earth.
Mark (mhpautos)
Apr 13, 2008 at 9:47 PM
