I would like to find out why my brake lights do not work i repalced the bulbs cleaned the connetion add di a light greese.check the fuse .also the high mount light still works but the tail lights do not work when you push on the brake pedal. tail lights work when you turn on the head lights. i tested the brake light switch undr the dash but it is working properly so please help .
May 14, 2009 at 4:08 PM
