1999 Pontiac Sunfire Turning car on
1999 PONTIAC SUNFIRE
137,000 MILES • 4 CYL • 2WD • AUTOMATIC
LOOM
  • 5 POSTS
When I try and turn my car on after sitting for 30 min or more, it hesitates for about 3-5 sec. If it sits for less then 30 mins it will start right up. Anyone know what the problem might be
Thanks!
Dec 21, 2007 at 5:05 AM
BLACKOP555
  • 10,386 POSTS
sounds to me that the car is releasing gas pressure due to a damaged fuel line or a bad fuel pressure regulator!
Dec 21, 2007 at 9:24 AM
LOOM
  • 5 POSTS
[quote:34cfcbeaf8="blackop555"]sounds to me that the car is releasing gas pressure due to a damaged fuel line or a bad fuel pressure regulator![/quote:34cfcbeaf8]
Heres whats up, I just put a new engine into the car, and I know its not the engine because it started fine in the other car i took it out of. When I hold my key in the start position for 5 secs the car starts fine and like I said before if the engine is still warm it starts right away. I had a mechanic look at the fuel pump and the fuel filter and both of those were fine, if I did fix the fuel line or the fuel pressure regulator how much would that cost, also how big of a problem is this... is it something i should get fixed right away?
thanks!
Dec 22, 2007 at 11:06 AM
BLACKOP555
  • 10,386 POSTS
fuel line is relatively cheap no more then 20 for all the lines.
for the regulator, it will be in the neighboorhood of 30-60 bucks. it is a pretty necessary replacement.
Dec 22, 2007 at 11:12 AM
LOOM
  • 5 POSTS
[quote:8f9ee51ffb="blackop555"]fuel line is relatively cheap no more then 20 for all the lines.
for the regulator, it will be in the neighboorhood of 30-60 bucks. it is a pretty necessary replacement.[/quote:8f9ee51ffb]
Do places charge a lot of labor on something like this?
Dec 22, 2007 at 11:31 AM
BLACKOP555
  • 10,386 POSTS
about 2-3hours labor, i dont know what the shops charge per hour of service there, maybe 400 bucks for all.
Dec 22, 2007 at 11:37 AM
LOOM
  • 5 POSTS
[quote:e371a9d5d6="blackop555"]about 2-3hours labor, i dont know what the shops charge per hour of service there, maybe 400 bucks for all.[/quote:e371a9d5d6]
thanks, im leaning towards it being a damaged fuel line, the car was in a front end collision before I purchased it, could this have caused damage to a fuel line?
thank you!
Dec 22, 2007 at 11:40 AM
BLACKOP555
  • 10,386 POSTS
that an many other things!
Dec 22, 2007 at 11:48 AM
LOOM
  • 5 POSTS
[quote:25ce0ef736="blackop555"]that an many other things![/quote:25ce0ef736]
Yeah I had to replace the wiring to the headlights because they were broken only one light would shine, also the car had a blown head gasket so I put in a new engine from another sunfire and now everything works great accept for that stupid starting up! but thanks for all the help!
Dec 22, 2007 at 11:50 AM
