1999 Pontiac Sunfire Tranmission slipping in 2 geer,and the
1999 PONTIAC SUNFIRE
DERRICK MOSS
1999 Pontiac Sunfire 4 cyl Automatic
Where is the speed sensor located on the sunfire and also the abs light is on the inside dashbord. I asked about the problems lastnight.
Oct 30, 2010 at 10:56 AM
FACTORYJACK
  • 4,159 POSTS
Which transmission do you have, the 4T40/5 or 3T40. Actually, the speed sensor on either is located out on the extension for the RF drive shaft. The ABS light coming on is going to set a code, that only a scan tool that communicates with the system, can retrieve.
Oct 30, 2010 at 11:29 AM
