1999 Pontiac Sunfire starter starts runnig after warning up
125,000 MILES • 4 CYL • FWD • AUTOMATIC
MANUEL064
Car starts fine and after warming up a little the starter starts runnig in park position only if i put the car in gear it stops, but if i put it in park again the stater engages again. What could be the problem ?5.00
May 8, 2009 at 1:00 PM
  • 75,988 POSTS
Sir -You need to test the ignition switch the only way for that to happen is its shorting out internally.
May 8, 2009 at 1:17 PM
