1999 Pontiac Sunfire Reving
DEZZIE41
Engine Mechanical problem
1999 Pontiac Sunfire 4 cyl Front Wheel Drive Manual 145xkm miles
ok heres my problem..i just put in a new motor in my sunfire GT 2.4L the new motor has 145000 KMS on it..i noticed this morning when u start it and after the engine cools down all the way..that when u start it when it is all the way on C on the guage it like to rev its slef up and down between idel and 2600RPM until the temp guage is off C...wut could that be an indication of>???
Thanks
Mar 1, 2009 at 9:23 AM
F4I_GUY
  • 3,302 POSTS
This could be an idle air control valve acting up. This valve controls an air passage while your throttle plate is closed. If you hold the throttle down a bit and the vehicle stops surging it is usually an IACV issue.
You can try cleaning the valve/ports/ throttle body first to see if this does any good. If not, you may have to replace the valve.
You should also check for vacuum leaks.
Mar 5, 2009 at 6:12 AM
DEZZIE41
tyhere are no leaks in vac lines...and she only does it whene shes codl i cant figure it out
Mar 5, 2009 at 7:11 AM
F4I_GUY
  • 3,302 POSTS
It's probably the IACV then.
Mar 5, 2009 at 10:01 AM
