1999 Pontiac Sunfire headlights
190,000 MILES • 4 CYL • FWD • MANUAL
CHAS_08
my low beams are both out (high beams are fine) but im pretty sure just needs new bulbs... but I have no idea how to get the headlight covers off! A little help?
Nov 29, 2009 at 12:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the air intake splash shield from the vehicle.
Remove the headlamp retaining bolts.
Remove the lamp assembly from the front of the vehicle.
Detach the headlamp connector.
Remove the headlamp bulb retaining ring.
Remove the headlamp bulb from the headlamp.
Insert the headlamp bulb into the headlamp.
Install and rotate the retaining ring until the tangs on the ring are engaged.
Attach the headlamp connector.
Place the headlamp assembly into place and tighten the retaining bolts.
Install the air intake splash shield.
Dec 4, 2009 at 3:04 PM
