1999 Pontiac Sunfire HAS NO SPARK
90,000 MILES • 4 CYL • FWD • MANUAL
PBURO
CHANGED COILS AND IGNITION MODULE CHECKED THE CRANK SENSOR AND OHM READING IS 1030 WHEN PULLED OUT CHECKED TO SEE IF VALVES TURN WHEN TURNING THE PULLEYS AND THEY DO I HAVE FUEL AND I CHECKED THE PCM FOR CORROSION WHAT ELSE COULD THIS BE IM RACKING MY BRAON TRYING TI FIGURE IT OUT. I SACN THE PCM AND I GET A CODE FOR AN EVAP PRESSURE SENSOR TO LOW BUT THIS SHOULDNT AFFECT THE SPARK ISSUE PLEASE HELP THANK YOU VERY MUCH
Feb 7, 2009 at 5:45 PM
  • 110,248 POSTS
Are you getting power to the coil?
Feb 20, 2009 at 11:53 AM
