1999 Pontiac Sunfire ENGINE METER RUNNING SHOWS RUNNING HOT
1999 PONTIAC SUNFIRE
164,000 MILES • 4 CYL • 2WD • AUTOMATIC
DARSELLE
WHERE IS THE THERMOSTAT LOCATED AND IS THERE A WEBSITE THAT I CAN GO TO TO SEE A VISUAL DIAGRAM?
ALREADY REPLACED
WATER PUMP
OVERFLOW CONTAINER
SERPENTINE BELT/SERPENTINE BELT TENSIONER
SPARK PLUG/SPARK PLUG SLEEVE
POLY-RIP BELT
AUTO BELT TENSIONER
HOSE CHECK OUT GOOD, NO LEAKS
FAN IS COMING ON
TRYING TO CHANGE THERMOSTAT BUT DON'T KNOW WHERE IT IS?
Sep 9, 2008 at 11:48 AM
BMRFIXIT
  • 19,053 POSTS
4 CYL
Engine size ??
2.2L follow coolant hose to engine and thermostat housing
2.4 L
its located under exhaust manifold
ENGINE SIZE???
Sep 9, 2008 at 10:44 PM
