1999 Pontiac Sunfire blower for heater and ac unit
1999 PONTIAC SUNFIRE
87,000 MILES • 4 CYL • FWD • AUTOMATIC
AHOFFER802Z
the blower on the above car only works on the highest speed and nothing else...I was told this could be a resistor problem. If so could you tell me where this is located?
Feb 26, 2010 at 3:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first check blower motor relay (in underhood fuse/relay center). if OK then go to the blower resistor. it is under the center of dash, in the HVAC assembly .
Feb 26, 2010 at 4:05 AM
