1999 Pontiac Sunfire anti theft locks engine start
147,000 MILES • 4 CYL • 2WD • AUTOMATIC
PBKRAMP
I switched a 1999 2.2 engine, trans, pcm, Into a 1996. When I try to start the car it runs for 1 second and dies. I've turned tie "key on" until the theft lock light stops flashing and then tried to start and it runs for only 1 second. I switched the ignition key, spliced the wires and tried the "learn" theft lock twice and still the 1 second start and die. Any suggestions would be great.
Apr 10, 2010 at 10:38 AM
  • 110,246 POSTS
You have to get the correct PCM with the same part number as the original one.
Apr 28, 2010 at 3:50 AM
