1999 Pontiac Sunfire
BOSSLADY459
  • 1999 PONTIAC SUNFIRE
Engine Performance problem
1999 Pontiac Sunfire 4 cyl Automatic
I have installed a new battery and I have a 1/2 tank of gas in it. It cranks but won't turn over. It has worked in the past, but has been sitting for 6 months. It seems like it is getting no fuel. What can I do?
Sunday, May 4th, 2008 AT 4:52 PM
MASTERTECHTIM
  • 4,750 POSTS
Try spraying starter fluid into it to see if it starts. If it does then you have a fuel issue if it does not then you need to remove a plug wire and have someone crank engine and watch if it sparks then get back to us
Sunday, May 4th, 2008 AT 5:05 PM
