1998 Pontiac Sunfire Turn signals/auto door locks/emergency
24,000 MILES • 4 CYL • 2WD • AUTOMATIC
IGORKAR
Hi. My 1998 Pontiac Sunfire has developed a problem when turn signals/emergency flashers and automatic door locks do not work for a periods of time. The fuses are OK, besides they seem always to fail simultaneously with no pattern. And just as simultaneously they come back up. Any diagnosis? Thanks>
Apr 4, 2008 at 11:29 AM
2CARPRO JACK
  • 11,533 POSTS
Those two circuits dont share anything as far as power goes. Does this car have an aftermarket alarm? If so I would go straight to it. The installers usually use "scoth-locks" , they break the wire and can create continuity problems
Apr 5, 2008 at 1:15 AM
IGORKAR
[quote:d200ef8e53="2CarPro Jack"]Those two circuits dont share anything as far as power goes. Does this car have an aftermarket alarm? If so I would go straight to it. The installers usually use "scoth-locks" , they break the wire and can create continuity problems[/quote:d200ef8e53]
Thanks for reply - no it does not have any alarms, either manufacturer's or aftermarket. There is a defenite dependancy in a way the turns signals/emergency flashers and powerlocks fail and then come back. Coincedence?
Apr 5, 2008 at 3:59 AM
2CARPRO JACK
  • 11,533 POSTS
The only place I can see where they would cross paths is if the alarm blinks the lights. cant see in my diagrams where they share any power or anything else
Apr 6, 2008 at 12:20 AM
