1998 Pontiac Sunfire Turn Signals
1998 PONTIAC SUNFIRE
BATUSZKING
Electrical problem
1998 Pontiac Sunfire 4 cyl Automatic 199254 miles
My turn signals are not working. I thought it was a simple answer by checking the fuses. I have had recent electrical work done. It has happened before prior to said electrical work. Do I simply have to replace a fuse or is there something else wrong?
Jan 4, 2010 at 11:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first check fuse and all bulbs. if OK then check turn signal flasher relay. if OK here as well then suspect faulty signal switch.
Jan 25, 2010 at 8:43 AM
