Car will run while starter is enaged. Dies immediately after Ignition switch turns to "run" position.
Dashboard warning lights do not illuminate at ANY TIME. (No Bulb check upon start). What controls the illumination of the lamps when the car is first started???
PCM reports "No Codes Found".
HELP.....
Thanks
HELP.....
Thanks
Dec 27, 2007 at 9:29 AM
