Hi, I have a 98 sunfire GT which I changed the air filter and drive belt on yesterday. Started it up ran great, went to start it later on that evening and it idled very rough and started chugging. I gave it a bit of gas for just a few seconds and once I let off it held the higher rpm on its own for maybe 5 seconds then drop down to normal idle rpm and the check engine light came on as well as the ETS light. I had to drive only a short distance to get the car home but during the drive the transmission was shifting a lot harder then normal. Any help would be greatly appreciated. Thank you!
Apr 2, 2010 at 12:42 PM
