1998 Pontiac Sunfire radiator
KOVACH12345
Engine Cooling problem
1998 Pontiac Sunfire 4 cyl Two Wheel Drive Automatic
i cant find the drain plug to drain my coolant i want to know where it is
Jul 22, 2008 at 7:06 AM
KLSHIEL
  • 163 POSTS
The drain plug on a radiator is at the bottom inside edge on one end cap or the other. You may not be able to see it from the top. A set of those ramps you can drive your car up onto may be the best way to get to it. It will be a plastic screw with tab sticking out to help turn it (like a wing nut). I will often use a pair of pliers to get more leverage, but be careful not to brake it.
Jul 22, 2008 at 7:23 AM
