1998 Pontiac Sunfire problem
222,000 MILES • 4 CYL • FWD • MANUAL
PONTIACSUNFIREGT2.4L
My 1998 Pontiac Sunfire GT 2.4L has a miss/bog in it from 1000rpm up to 3000rpm and only if it is given lots of throttle, if it is gradually given throttle it doesnt do it. I changed
Dec 2, 2008 at 6:27 AM
F4I_GUY
  • 3,302 POSTS
Whens the last time you had a tune-up? A common problem with these cars is the holder that contains the coil/wires. It's the piece you have to remove to access the spark plugs. Usually the spark will short to ground through a faulty component in that unit. Remove it and look for burn marks or white marks that would indicate a a short to ground.
Your problem sounds like a mis-fire and that's where I'd start with your vehicle.
Dec 2, 2008 at 10:06 AM
