My oil pressure light flashes intermittently?
BRANDONMC1
Other Category problem
1998 Pontiac Sunfire 4 cyl Wheel Drive Type unknown Manual 118,00 miles
My oil pressure light flashes intermittently. It seems as if it does it most when the car is stopped at a light. It doesn't do it everyday, maybe once a week or so. I have recently had the clutch replaced and when I did they also replaced the sending switch. Should I be worried?
Dec 12, 2007 at 10:24 AM
  • 75,988 POSTS
Get the oil pressure check-could be the oil pump or engine bearing problems. The light coming on means the oil pressure is low-something is amiss.
Dec 12, 2007 at 12:11 PM
  • 55,658 POSTS
It sounds like the engine oil level is low or the oil pump pickup screen is clogged. Here is the location of the oil pressure sender which is here you would install the oil pressure gauge. I have also included how you can change out the oil pump incase it is weak. Check out the images (below). Let us know how it goes
Aug 25, 2024 at 4:01 AM
