1998 Pontiac Sunfire interior lights
130,000 MILES • 4 CYL • FWD • MANUAL
FFFCAT
cannot get the interior dome light, rear view mirror map lights and trunk light , and power mirrors to work. Rest of functions on the fuse works such as warning chimes, radio, and keyless entry. Is there one wire that feeds just the lights?
dflater27@sbcglobal.net
Nov 7, 2010 at 6:47 AM
JDL
  • 16,098 POSTS
Did you check this fuse for voltage? Use a voltage tester. In the other diagram, the top orange wire voltage from the fuse I mentioned. The lower orange wire is voltage to the dome light. Also, ground could be an issue?
https://images.2carpros.com/forum/automotive_pictures/170934_sunfire_interior_lights_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_sunfire_interior_lamp_fuse_1.jpg
Nov 7, 2010 at 7:40 AM
