1998 Pontiac Sunfire headlamps
87,000 MILES • 4 CYL • 2WD • AUTOMATIC
ELVIS243
my low beam headlamps don't work. I have checked fuses, bulbs and they are working fine. My high beams and DRL works fine . any suggestions
Mar 12, 2009 at 5:26 AM
YOGITECH1
  • 13 POSTS
It is possible that the dimmer switch is bad.
Mar 12, 2009 at 5:39 AM
ELVIS243
what and where is a dimmer switch and how do you check that?
Mar 12, 2009 at 8:19 AM
YOGITECH1
  • 13 POSTS
I the switch is not on the floor as in older vehicles then it is part of the turnsignal assembly, just puul it towards you and this should toggle the switch. If it doesn't then it is defective.
Mar 12, 2009 at 11:37 PM
ELVIS243
I pulled the the turn signal assembly towards me and the high beams go on. Still nothing with the low beams
Mar 13, 2009 at 2:23 AM
YOGITECH1
  • 13 POSTS
the problem could still be either the high beam switch or the head light switch itself.
Mar 15, 2009 at 8:22 AM
