1998 Pontiac Sunfire 1998 sunfire, i have no dome, glove bo
140,000 MILES • 4 CYL • FWD • AUTOMATIC
DRE414
1998 sunfire, i have no dome, glove box or trunk light, checked the fuses checked the door switches all are fine. i have power at the fuse and door chimes work with the door switches but no lights, bulbs are fine..
Dec 16, 2009 at 9:56 AM
KHLOW2008
  • 41,812 POSTS
Hi dre414,
Thank you for the donation.
Did you test for power supply at the various lights?
Power from the Interior Lamp Fuse ( 10 A) is sent to the Multifunction Alarm Module ( in Convenience Center, on top of right kick panel) and distributed to the various courtesy lights.
Check if the Orange wire to these components have battery voltage.
Dec 19, 2009 at 3:47 PM
DRE414
Hello, now just to varify the convienience center is the middle of the dash? under the radio and heater cnt cluster?
Dec 20, 2009 at 5:47 AM
KHLOW2008
  • 41,812 POSTS
The information from our database indicates the convenience center is under end of right dash, above the kick panel, behind the glove box.
Dec 21, 2009 at 1:38 AM
