since then I have changed just the coils, without back plate. And I have also tried other back plates just the original will start it.
I have checked the spark-plugs for fire. They all fire nice.
I have also changed the knock sensor on the bottom of the block. I have changed the cam sensor.
I have checked the fuel pressure it looks good, it had 55 psi. I changed the gas filter.
I have connected a ob II code reader to it. It says all is ok no codes.
I have also removed the remote starter.
I have been working on this problem for weeks now. I would really appreciate hearing your opinion. Thank you.
SPONSORED LINKS
Tuesday, August 18th, 2009 AT 1:11 AM
