is engine cranking over at all? or you just getting a click noise when turning key? any electricals working i.e. radio , headlights etc..
Mar 28, 2010 at 3:24 PM
KELLYCLARK
MEMBER
yes it is turning over and all lights are coming on
Mar 28, 2010 at 3:36 PM
BLUELIGHTNIN6
✓Experienced Mechanic
you will need to check for fuel pressure and healthy spark then. engine has to get proper fuel and spark supply. if both are OK then check compression on cylinders.
