Hello, if the starter won't crank, check the starter circuit. Make sure the battery has a full charge and the cables are good. Did you try cranking in neutral? With the key in the crank position, the S terminal on the starter solenoid should be hot.
SPONSORED LINKS
Friday, June 19th, 2009 AT 2:05 PM
