1997 Pontiac Sunfire low end engine knock
1997 PONTIAC SUNFIRE
BROTHERB
Engine Mechanical problem
1997 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic n/a miles
i drove in the drive one day when i had noticed that the engine was overheating so i poped open the hood quickly after turning the car off and watched the coolant running right out of the coolant tank.i let it sit for about 45 minutes fild the coolant but when i went to drive down town i noticed the hotter the engine got the low end knock got louder.do you think that it could have been caused by the overheating and coolant loss and even though the first thing i think is it damaged the engine but could the knock be coming from the tansmission.the sound always becomes intensified when i excelerate but when i sit and idle the car the engine seems to run fine with no knock.
Aug 10, 2008 at 7:27 PM
SERVICE WRITER
  • 9,123 POSTS
Does the knock occur if you are in park and rev it?
IF so, It sounds like a spun bearing problem.
Aug 10, 2008 at 10:46 PM
