1997 Pontiac Sunfire Loud noise
1997 PONTIAC SUNFIRE
CABJ1905
Steering problem
1997 Pontiac Sunfire Engine Size unknown Wheel Drive Type unknown Automatic 69000 miles
When ever I'm driving and I tilt the steering wheel to the right, for example just to change lanes, I hear a loud noise underneath the car and only happens when I tilt the wheel slightly to the right, what do you think the problem is?
Thank you in advance for your time and help.
Feb 24, 2008 at 11:56 PM
MASTERTECHTIM
  • 4,750 POSTS
your problem is a hub bearing. very common and you are describing it perfectly. which side can sometimes be confusing. its either the left or right front usually.
Feb 25, 2008 at 1:06 AM
