1997 Pontiac Sunfire cuts out while cruisng
100,000 MILES • 4 CYL • FWD • MANUAL
JOESHOVZ
my 1997 sunfire seems to cut uot while cruising at around 2000-3000 rpm. btu it seems to stop when I give it gas. seems like fuel restriction but then it should studder when I step on it,right .anyone who can help please do .thanks
Nov 25, 2008 at 11:50 AM
JON GAUDET
i had that problem with my 2000 sunfire and try a new battery because the sides of the battery were puffed out the coil pack needs 12 volts constantly so if u have a bad battery or alternator it will cause this problem hope this helps let me know
Dec 5, 2008 at 4:57 PM
JOESHOVZ
thanks for your reply , I found that changeing the coil packs solved the prob.
Dec 6, 2008 at 2:35 AM
