1997 Pontiac Sunfire check engine /crank sensor
1997 PONTIAC SUNFIRE
90,000 MILES • 4 CYL • FWD • AUTOMATIC
HOTTIE72
check engine light computer said crank sensor replaced 4 times will run for about 20 minutes then starts to sputter and check engine light comes back on help
Dec 28, 2007 at 10:45 PM
BMRFIXIT
  • 19,053 POSTS
[quote:caebee7489="hottie72"]Other Category problem
1997 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic 90,000 miles
check engine light computer said crank sensor replaced 4 times will run for about 20 minutes then starts to sputter and check engine light comes back on help[/quote:caebee7489]
what is the code ?
code #
did you check the wiring
if short in wiring ECM will give false codes
just because no responed from that sensor does nt mean the sensor bad
post the code and let see if we can get to the bottom of this together
Dec 28, 2007 at 10:52 PM
HOTTIE72
just said crank sensor
Dec 28, 2007 at 11:00 PM
BMRFIXIT
  • 19,053 POSTS
[quote:f8468fd4a7="hottie72"]just said crank sensor[/quote:f8468fd4a7]
it should also have a code with that
like P####
if you can get that
Dec 28, 2007 at 11:02 PM
