1997 Pontiac Sunfire cant shift
TAMMYT
1997 Pontiac Sunfire 4 cyl Front Wheel Drive Manual
my car will not shift i changed the slave cylinder and the master cylinder it only shifts if the car is off
Aug 30, 2009 at 10:39 AM
  • 110,248 POSTS
If they are replace and working properly, then chances are the pressure plate is bad or the clutch disc is worn. Does it grind when you try to shift?
Sep 7, 2009 at 4:00 PM
