1997 Pontiac Sunfire 2.2 timing chain
JESSE211
  • 1997 PONTIAC SUNFIRE
Engine Mechanical problem
1997 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
i have a 97 pontiac sunfire with the 2.2. Can I change the timing chain with the motor in the car. Thanks for your time
Sunday, December 6th, 2009 AT 10:33 AM
HINSPATE
I have a manual transmission 97 sunfire with 2.2L engine. I assume the timing chain and related parts are the same on your vehicle. If so, the answer is "yes you can." I just got done with that repair on my car. I bought a Chilton repair manual, and it was sufficient to guide me through the repair. I recommend getting some help from a friend, as we found we needed more than two hands at times. Good luck!
Tuesday, December 8th, 2009 AT 10:15 AM
