1996 Pontiac Sunfire Thermostat
1996 PONTIAC SUNFIRE
NO1JAXX
Heater problem
1996 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
How do you replace the thermostat in a 96 pontiac sunfire?
Feb 5, 2009 at 7:29 PM
SAWMASTER88
  • 38 POSTS
The thermostat should be at the end of the upper radiator hose. Start by removing the thermostat housing. (Should be a couple of small bolts). Once it is off you should be able to see the thermostat. Pull it and the old thermostat gasket out. Replace with new thermostat and thermostat gasket. Put housing back down and tighten bolts. Check to make sure your coolant level is still good and you should be on your way. Good luck and I hope this helps.
Feb 13, 2009 at 10:00 PM
