1996 Pontiac Sunfire ignition switch
1996 PONTIAC SUNFIRE
RKB67
Electrical problem
1996 Pontiac Sunfire 4 cyl Wheel Drive Type unknown Automatic 128000 miles
how hard is it to change the ignition switch and do i have to mess with the airbags?
Jan 17, 2008 at 7:33 AM
MASTERTECHTIM
  • 4,750 POSTS
its not hard. but you need special tools. it is held in by inverted torx bolts. so you will need to get a set of those. i had to grind mine down to get it small enough to fit the bolts. remove the upper and lower cover around ignition switch. then reevaluate. hope this helps. feedback is much appreciated.
Jan 17, 2008 at 7:43 AM
