1996 Pontiac Sunfire Faulty Brakes.
MARYMURPHY1
Brakes problem
1996 Pontiac Sunfire 4 cyl Two Wheel Drive Automatic 163K miles
About 2 days ago after driving my car about 20 miles, when i tried to apply pressure to my brakes they went all the way to the floor, and I have limited brakes. They havn't seem to have gotten any worse over the past 3 days and i checked the brake fluid, and it's fine. What could this be? And is it possible they could go completely, because i've still been driving it.
Jul 21, 2008 at 6:15 AM
MMPRINCE4000
  • 8,548 POSTS
First jack the car up and put on stands, check the front calipers for any fluid leakage as well as the rear wheel cylinders and hoses/hard lines.
Since your fluid level is good, it is more than likely a master cylinder is bad.
It is very dangerous to drive a car with brake problems. Don't drive it until the brakes are repaired.
Jul 21, 2008 at 6:41 AM
DOCFIXIT
  • 18,828 POSTS
Internal piston seals bad in master cylinder. And yes it is dangerous to and it could get worse.
Jul 21, 2008 at 6:44 AM
