1996 Pontiac Sunfire Dim Lights
NUNO281
  • 1996 PONTIAC SUNFIRE
  • 4 CYL
  • FWD
  • MANUAL
  • 20,000 MILES
Hello my sunfire has lately been having these dim lights and when I say lights I mean the whole thing from the headlights to the stereo. When I put the turn signal it blinks very slow and my headlights dont shine like they use to please help.
Wednesday, March 10th, 2010 AT 7:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Must have a weak battery. Have battery and alternator tested. Also check battery cables to ensure they are clean and tight.
Wednesday, March 10th, 2010 AT 9:08 PM
MIKE H R
  • 3,094 POSTS
If it starts all right then check the wire coming from the battery to the fuses, may be corroded or loose. Just because a wire looks good on the outside there could be a build up on the inside you don't see and make sure there are good connections.
Thursday, September 22nd, 2016 AT 7:04 PM
