1996 Pontiac Sunfire Crankshaft Position Sensor won't fit
187,000 MILES • 4 CYL • FWD • AUTOMATIC
B2THAKING13
  • 6 POSTS
I have a 96 sunfire 2.2 L engine. I recently bought it and the engine wase'nt put together so I had a personal mechanic do it for me and I bought a crankshaft position sensor with 3 prongs inside of it, but my wire connector has 4 holes and doesnt fit. GM says they never made a 4 prong sensor The guy I bought it from doesnt know what car the engine originally came out of. My question is can I just have the crankshaft position sensor wire changed to match up with my sensor or will I need an entirely new wiring harness? Or am I reaching for the wrong wire?
Mar 15, 2010 at 12:46 PM
  • 110,248 POSTS
Have you contacted a dealer? I know I've seen them with 4 pins. Also, is the engine the original one?
Mar 15, 2010 at 4:01 PM
B2THAKING13
  • 6 POSTS
I talked to a parts dealer who looked for one for my year, the year before and up to 2000 and did'nt find one. And no it isn't the original engine and the original owner I bought it from doesn't know where it came from he just bought it used and never had it put together and sold it to me, but I have a 1997 Sunfire and the engines are nearly identical.
Thank you
Mar 15, 2010 at 10:40 PM
  • 110,248 POSTS
See if you can make it work with the 3 pin. However, something tells me there is going to be a problem.
Mar 16, 2010 at 4:01 AM
B2THAKING13
  • 6 POSTS
The wire doesn't fit at all I've tried and I have yet to find a 4 hole sensor. I wish I could
Mar 16, 2010 at 9:20 AM
  • 110,248 POSTS
I just went through cavaliers, sunbird, sunfire... from 1990 through 2000 including 2.2 and 2.4 and can not find a 4 pin, but I know I have seen them.
A friend of mine owns a salvage yard. I will try to make it there this weekend and check it out. He has a row of wrecked ones.
I'll let you know what I find.
Mar 16, 2010 at 3:43 PM
B2THAKING13
  • 6 POSTS
Alright well just let me know. It'll help a lot
Thank You
Mar 17, 2010 at 1:51 PM
RHALL77
  • 3,361 POSTS
whats the shape of the connector and the color of the wires?
Mar 23, 2010 at 8:04 AM
B2THAKING13
  • 6 POSTS
the connecter is long lenth wise and short height wise. rectangular. the wires are im not sure.
Mar 23, 2010 at 10:21 AM
  • 110,248 POSTS
I looked at about 15 of them. Everyone had a three prong connector. Have you tried contacting a dealer to see if they have any suggestions?
Mar 23, 2010 at 2:38 PM
RHALL77
  • 3,361 POSTS
you need to get me the wire colors so I can trace them down in a wire scematic. that way I can help you better
Mar 24, 2010 at 1:07 AM
B2THAKING13
  • 6 POSTS
well i finally broke down and took it to a garage apparently I need a new wiring harness. Is it worth it?
Mar 24, 2010 at 9:08 AM
  • 110,248 POSTS
How much are they charging you?
Mar 24, 2010 at 4:03 PM
