1996 Pontiac Sunfire coolant fan not cycling on it's own
1996 PONTIAC SUNFIRE
125,000 MILES • 4 CYL • FWD • AUTOMATIC
DELAMORTE
I have replaced the coolant temperature sensor, relay, and fuses. The fan is not responding to the temperature sensor. The fan will work when defrost or a/c is engaged. Vehicle has no coolant leaks. Just replaced the water pump and pressure test shows no sign of issues. Mitchell points to new pcm. Anything else I can try before I resort to buying a pre-flashed computer??
Jun 2, 2009 at 1:01 PM
Sounds like PCM is not picking up the CTS signal and not activating the relay to fire up the electrci fan motor
Jun 2, 2009 at 1:04 PM
DELAMORTE
Using a Solus I can read the coolant temperature sensor.
Jun 2, 2009 at 1:07 PM
