Electrical problem
1996 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
how to remove the alternator? Do not know how to remove tensioner
Thursday, May 7th, 2009 AT 6:50 PM
00SUNFIREGT
MEMBER
There should be a bolt on the inside of the tensioner pulley, turn it as if you are tightening it, it should the move the whole arm and loosen the belt, be careful cause there is a lot of tension
