1996 Pontiac Sunfire 1996 Sunfire NO SPARK
EANDEGARAGE
Electrical problem
1996 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
Have a 96 Sunfire with no spark. I have tried new module, new cam and crank sensor, used numbers matching pcm and the coil packs check good. But still no spark. Any help would be appreciated.
Feb 6, 2009 at 8:51 AM
MERLIN2021
  • 17,250 POSTS
Try checking the timing and compression, if the belt jumped, the cam and crank sensors arent synced, and the pcm may be killing spark. you can try unplugging the cam sensor, see if you get spark as a quick test.
Feb 6, 2009 at 9:21 AM
