HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Sunfire
Engine
Cylinder Head
Gasket
1995 Pontiac Sunfire routing diagram
JYC_MCKNNY
MEMBER
1995 PONTIAC SUNFIRE
Engine Mechanical problem
1995 Pontiac Sunfire 4 cyl Two Wheel Drive Automatic
I need a picture of a routing diagram for my 1995 pontiac sunfire. I need to find out how to put on a head gasket. Pictures will help.
Saturday, September 6th, 2008 AT 11:04 PM
OBXAUTOMEDIC
MECHANIC
Need a little more info to get correct info for you.
What is Sub-Model ---- GT or SE
And what is engine size in Liters 2.2 or 2.3
Also the routing you are looking for is it the Drive Belt or the Timing.
Saturday, September 6th, 2008 AT 11:26 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Content
1997 Pontiac Sunfire Head Gaskets And If My Engine Is...
I Have A Pontiac Sunfire 97. My Car Was Over Heating One Day And So I Was Thinking I Should Buy Coolant. A Guy From Jiffy Lube(i Know Dumb...
Asked by
nessa_bo_bessa91
1997
PONTIAC SUNFIRE
VIDEO
Can You Fix a Head Gasket with a Sealer?
Instructional repair video
GUIDE
Cylinder Head Gasket Blown Symptoms
A head gasket failure must be caught early to help protect the engine from additional damage. Understanding and recognizing these symptoms will be beneficial to your ...
Head Bolt Torque Specs
Need Head Bolt Torque Specs For '97 Pontiac 2.2
Asked by
chief1887
1 ANSWER
1 IMAGE
1997
PONTIAC SUNFIRE
What Would Cause The Engine To Sound Like Air Is...
From The Engine In A Pattern About Ever Second When Idling? Ex. Psht, Psht, Psht With Some Help I Took On The Task Of Replacing The Engine...
Asked by
cmille82
2001
PONTIAC SUNFIRE
1997 Pontiac Sunfire Motor
I Need To Know If You Have To Change The Heads If You Put A Motor From A 2000 Model Sunfire Into A 1997 Sunfire
Asked by
billy76w
1 ANSWER
1997
PONTIAC SUNFIRE
1995 Pontiac Sunfire 108690
I Take A 120 Mile Drive Home Every Weekend, After About An Hour Of Driving My Car Turns From Dr Jekel To Mr Hyde. I Travel At Consistent...
Asked by
krusher
1995
PONTIAC SUNFIRE
VIEW MORE
Coolant Mixing With Engine Oil
Change Engine Oil and Filter Ford Edge
