1995 Pontiac Sunfire lousy running
1995 PONTIAC SUNFIRE
MLEE1963P
Engine Performance problem
1995 Pontiac Sunfire 6 cyl Front Wheel Drive Automatic
when u start up in morning runs fine , after warms up it spits and sputters then quits. let it set and cool down and will start up and run fine untill warms up again . kind of like its not getting any gas
Feb 8, 2009 at 11:38 AM
SAWMASTER88
  • 38 POSTS
It could be your Ignition Control Module. When the module is put in, there is grease put below it to help as a heat insulator, and over time that grease can dry up. When the module gets hot it tends to not work well. I would take the module off and take it to your local auto parts store and ask if they can test it for you. Good luck and I hope this helps.
Feb 13, 2009 at 10:02 PM
